Is it possible to trigger a new Pagerduty incident for an existing ServiceNow P2 ticket?
Question - Is it possible to trigger a new Pagerduty incident for an existing ServiceNow P2 ticket?
Overview
We have ServiceNow integrated with Pagerduty, works great. Currently triggers a Pagerduty incident anytime a P1 or P2 incident is logged in our ServiceNow environment, for specific assignment groups (teams).
The use case we are thinking of is,
Use Case - Existing SNOW ticket, is owned by an engineer and if the status of the ServiceNow ticket changes from ‘Assigned’ to “Escalated” or something else.
Question - Can we configure Pagerduty to “re-trigger” a new PD incident to notify the on-call engineer?
as a suggestion:
If defined “Impacted Service” of the incident is different from the on-call engineer “Escalation Policy” , so it will re-trigger every one or two hours (depends on P1 or P2).
Then the on-call engineer can Acknowledge it, and snooze it for the duration he is on-call. after that, it will re-trigger automatically.
Hope it helps.
Ehsan
Hi Dawud Bey,
Thank you for reaching out via our support community page. In order to better assist you with your query can you please raise a support ticket at support@pagerduty.com so that we can consult you further as there might be a possibility of troubleshooting this over a screen-share.
Thanks,
You could initiate an Add Responder or Run a Response play to essentially notify a different on-call engineer or team. This could be handled in SNow logic and interact with our PagerDuty APIs.
